Posted: 2020-07-02 06:17 PM . Last Modified: 2024-04-09 02:01 AM
Dear Team,
We have a scenario to integrate NBRK 201 with Unitron M1 system using MIB 4.1.0 version
and we found the unitron system can not get real parameter from our NBRK 201
is there any solution regarding this issue
(CID:105456925)
Hi Yosef,
If you are looking to integrate the NetBotz 200 (NRK0201) with an SNMP server or NMS, you do first need the MIB. You mention 4.1.0 and I can only assume you're referring to the NetBotz mib. You would instead want to go to:
www.apcc.com/tools/download and download the powernet mib as the NetBotz 200 is based on the network management card technology such as is found in an NMC you would add to a UPS. It is not the same technology as the 3xx, 4xx, and 5xx and does not use that MIB.
Steve
(CID:105456994)
Hello Yosef, To better support this issues we will need a little more information. 1. Have you tried another program like GetIf to walk the NetBotz 200 to verify that the unit is responding to SNMP request? 2. What OIDs is the Unitron system using to request device information. By providing the information above we can test exactly what SNMP information your are trying to monitor. Thanks Victor
(CID:105456995)
Posted: 2020-07-02 06:17 PM . Last Modified: 2023-10-31 11:21 PM
