DCO 7.5 SP3 supported in RHEL installation
  • EcoStruxure IT forum
  • DCO 7.5 SP3 supported in RHEL installation
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:16 PM . Last Modified: ‎2024-04-09 02:01 AM
524
Could you please advise if DCO 7.5 SP3 is supported in RHEL installation?
Regards
Jim Davis - NIE Melb/AU
(CID:105456922)
  • Data Center Operation
Hi Jim, We will verify this and get back to you as soon as possible. Thanks Jesper
(CID:105456984)
 Hi Jim
We have verified SP3 on RHEL 6.5. The instruction for the copy commend has changed a little. The rest of the commands are the same.
You will have to use the right user to copy the files - that might not be jboss as mentioned in the sp3.txt file (perhaps dcojboss):
The username can be found by issuing the command:
Platform.pm get-jboss-username --silent
And then replace that with in the copy commands below.
sudo -u cp ISXO_Core.ear /opt/jboss-as/server/isxo/farm/ISXO_Core.ear
sudo -u cp ISXO_WebApp.war /opt/jboss-as/server/isxo/farm/ISXO_WebApp.war
sudo -u cp com.apc.sslutils.jar /opt/jboss-as/server/isxo/lib/com.apc.sslutils.jar
sudo -u cp swoExportJob_v2.0.0.kjb /data/pentaho/export/swoExportJob_v2.0.0.kjb
sudo -u cp swoPortConfiguration_v2.0.0.ktr /data/pentaho/export/
Jesper
(CID:105456986)
Posted: ‎2020-07-02 06:16 PM . Last Modified: ‎2023-10-31 10:47 PM
