Posted: 2020-07-03 03:30 PM . Last Modified: 2024-04-08 12:56 AM
hello, we have MGE Upsilon STS 250 installation whit 66074 communition card.
http://www.apc.com/shop/au/en/products/MGE-SNMP-Web-Card/P-66074
in DCE this unit use mge ups ddf not a mge sts ddf.
do i need sam additional setup for 66074?
(CID:116924812)
Hello Darius,
Normally it does not require any additional set up, just connect the card to the slot and discover the device in DCE and that should work fine.
Please let us know if you have any problems in viewing the parameters in DCE.
Thanks and Regards,
Mohan Gowda
(CID:116926245)
Posted: 2020-07-03 03:30 PM . Last Modified: 2023-10-22 02:59 AM
