PCBE and DCE
Showing results forΒ
Did you mean:Β
  • PCBE and DCE
126
65
Posted: β€Ž2020-07-03 03:28 PM . Last Modified: β€Ž2024-04-08 12:57 AM
1680
PCBE and DCE
Im already using DCE in my datacenter.  I'm wondering if I can leverage PCBE via DCE to monitor some 1500 UPS devices that do not have NMCs installed.  Any input on that would be appreciated.  I saw somewhere Someone may have been doing this but have to create their own DDFs for thresholds.
(CID:116924279)
Replies 18
Top Google search comes up with the Philadelphia Council for Business Economics.
I don't think that will work.
What's PCBE???
(CID:116924294)
Power Chute Business Edition?
(CID:116924296)
1679
Hi David,
Yes, PowerChute Business Edition on a Windows system can be monitored by DCE provided the operating system's SNMP service is configured and running prior to the PCBE install. You will get basic data but no alerts by default. You will need to manually configure thresholds in DCE for each agent. That is not the same as creating DDFs.
Steve.
(CID:116924304)
Posted: β€Ž2020-07-03 03:29 PM . Last Modified: β€Ž2024-04-08 12:57 AM
awesome.  Thanks Steven.  Mostly I want to be able to head off battery replacements.
(CID:116924329)
Steven Marchetti, and for this you do not need a separate DDF-file (for PCs with Windows OS and PCBE)?
 Very thanks for the support.
(CID:116924344)
That is correct Spezialist. You can create a manual threshold for any sensor. You do NOT need another DDF.
(CID:116924357)
Thanks for the answer.
And since which version of PCBE for Windows is it possible?
(CID:116924373)
Any version of PowerChute Business Edition for Windows has supported SNMP and before that, PowerChute Plus. As for the version of DCE, I believe the PCBE DDF was added in 7.0 but it could have been a little sooner or later.  Please note that this is different than PowerChute Network Shutdown which does not monitor the UPS. If you are using PCNS, the UPS has an NMC installed and you would monitor that NMC IP to monitor the UPS.
(CID:116924379)
Very interesting, I will definitely try one of these days.
But I doubt, that there is a PCBE DDF-file on the current DCE-7.x server. I do not find it there: there is only a PCNS DDF-file. And in DEVICE SUPPORT, I also find only PCNS...
(CID:116924385)
Do you see a listing for APC PCBE?
(CID:116924388)
I do not quite understand... Is there a PCBE software specification?
(CID:116924402)
Thanks for the input.  I see a DDF version 2 input for PCBE in DCE 7.4.3 so I figure Im good.
Looks pretty straight forward.
(CID:116924404)
Posted: β€Ž2020-07-03 03:30 PM . Last Modified: β€Ž2024-04-08 12:56 AM
David got it!
πŸ˜ƒ
(CID:116924408)
Indeed, thanks for the tip: I just did not look there πŸ˜€.
Thanks again for the support.
(CID:116924409)
Ok, if there was only a Windows OS with PCBE and UPS, it was SOLVED πŸ˜€.
(CID:116924411)
Yes no Linux in the mix, only windows for now.
(CID:116924412)
Hi dave.lively,
Unfortunately, what you want is almost impossible, since the basic communication protocol for the DCE-server is the SNMP protocol. And, if the PCBE software had a built-in snmp server (as in PCNS-4.2), theoretically, one could write a DDF-file for monitoring PCBE software installed on a PC. But I'm not sure that this way it would be possible to monitor the sensors of the UPS connected to this PC (via COM or USB port). I crossed out this, because according to the message Steven Marchetti it's still possible, although only a PC with Windows OS. Look also my similar topic
In addition, starting with the version of DCE-7.4.3.26, the updated DDF-file pcns.xml v3 is supplied. This updated DDF-file now allows you to see these "sensors" of the server with installed PCNS software (previously only Link Status was displayed):
With best regards.
(CID:116926241)
Posted: β€Ž2020-07-03 03:30 PM . Last Modified: β€Ž2023-10-22 03:29 AM
