Low superheat warning
  • EcoStruxure IT forum
  • Low superheat warning
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-11-24 12:37 AM
17890
I have been getting this warning from my ACRD602P unit.
It's an hot aisle POD, this unit is 1 of 2 units in that POD.
Valentin_Kozlov
Lieutenant Valentin_Kozlov Lieutenant
Lieutenant
Posted: ‎2020-11-25 03:11 AM
Hi!
You need to paid attention to your cooling unit.
A low or zero superheat reading indicates that the refrigerant did not pick up enough heat in the evaporator to completely boil into a vapor. Liquid refrigerant drawn into the compressor typically causes slugging, which can damage the compressor valves and/or internal mechanical components.
Valentin_Kozlov
Lieutenant
Hi!
Billark
Billark
Cadet
Posted: ‎2023-03-05 05:02 AM . Last Modified: ‎2023-03-05 05:07 AM
Low superheat in a refrigeration or air conditioning system can be caused by several factors, including:
Overcharging of refrigerant: When the refrigerant charge in the system is too high, the system will have low superheat. This is because there is an excess of refrigerant in the system, which can cause the refrigerant to evaporate at a lower temperature than normal, resulting in low superheat.
Underfeeding of refrigerant: When the refrigerant is not properly fed to the evaporator, it can cause low superheat. This can happen due to a faulty thermostatic expansion valve, which can limit the amount of refrigerant that is allowed to enter the evaporator, resulting in insufficient cooling and low superheat.
Insufficient airflow over the evaporator: When there is insufficient airflow over the evaporator, it can cause low superheat. This can happen due to a clogged or dirty air filter, a malfunctioning blower motor or fan, or a blocked or damaged ductwork, which can reduce the amount of heat that is transferred from the air to the refrigerant, causing the refrigerant to evaporate at a lower temperature than normal.
Malfunctioning compressor: A malfunctioning compressor can also cause low superheat. This can happen due to a faulty compressor valve, worn or damaged compressor components, or a faulty compressor motor, which can cause the refrigerant to circulate at a lower rate, resulting in insufficient cooling and low superheat.
Incorrectly sized metering device: When the metering device, such as a thermostatic expansion valve or a capillary tube, is incorrectly sized, it can cause low superheat. If the metering device is too small, it can restrict the flow of refrigerant into the evaporator, resulting in insufficient cooling and low superheat. If the metering device is too large, it can allow too much refrigerant to enter the evaporator, resulting in excess cooling and low superheat.
