Is there any additional option to extend leak rope beyond 100 m?
  • Is there any additional option to extend leak rope beyond 100 m?
126
65
Posted: ‎2020-07-04 11:47 PM . Last Modified: ‎2024-04-04 02:26 AM
1182
According to installation sheet 990-3374 the Leak Sensor NBES0308 can be extended the total length up to 30.5 m (100 ft) using Leak Sensor extensions (NBES0309).
  1. ¿Is there any additional option to extend leak rope beyond 100 m as Emerson (Vertiv) does?
  2. ¿Is it possible to extend third party leak rope beyond 100 m using 4-20 mA Sensor Pods?
  3. Or maybe through Dry contact option?
Thank you in advance
(CID:134033539)
  • IT Expert
  • NetBotz
1182
Hi Victor,
Here's the link to the install guide:
http://www.apc.com/salestools/JSAI-7EVPBS/JSAI-7EVPBS_R0_EN.pdf
As it states clearly, the limit is 100 feet (not meters): You can not extend the leak rope farther than this.
Note: You can extend the total length of the Rope Leak Sensor up to 30.5 m (100 ft) using NetBotz 6.1-m (20-ft) Rope Leak Sensor Extensions (NBES0309).
If you need to go farther than this, you will either need another device or you can use spot leak sensors. A NetBotz appliance with sensor pods connected via A-link and cat-5 cables (with some pods powered) can extend up to 1000 meters as per k-base FA156085..
Thank you,
Steve
P.S.
You can use 4-20mA sensors and any distance limitation would be based on the connected device. I have no product suggestions to make.
(CID:134033544)
Replies 4
1183
Hi Victor,
Thank you,
Steve
P.S.
(CID:134033544)
Steven,
Can a second leak rope sensor be connected in one of the Sensor Ports, or is the Leak Rope sensor the only port where one can be installed?
Thank you,
Riley
(CID:134035013)
Posted: ‎2020-07-04 11:48 PM . Last Modified: ‎2024-04-04 02:26 AM
Hi Riley,
there is only a single leak rope port in the current NetBotz offerings. You can add a spot leak but if you need more rope leak, you need a second unit. The “universal” sensor ports will not communicate with the leak rope.
Steve.
(CID:134035051)
Posted: ‎2020-07-04 11:48 PM . Last Modified: ‎2023-10-22 02:51 AM
