Posted: 2020-07-05 10:11 PM . Last Modified: 2024-04-03 12:33 AM
Good day
Is possible configure the protocol SNMP V3 in the DCE for the server, because for default the server active the agent SNMP (read and write community, port, contact and ubication) but not is possible select that kind of version and/or configure.
From the console it is possible to configure something or not (SNMP v1, v3, etc).
Thanks…
(CID:148770623)
Posted: 2020-07-05 10:12 PM . Last Modified: 2024-04-03 12:33 AM
Hi Leo,
Currently the DCE server only has SNMP version 1 capabilities. There is no option to monitor the system using SNMP version 3. Please also note that there are only a few server OS based values that can be monitored. No information about the DCE sub-system or any of the nodes being monitored can be obtained via SNMP.
Thank you,
Steve.
(CID:148770626)
Hi Steve,
Thanks for your reply. I needed to know if this possibility was possible.
(CID:151060615)
Posted: 2020-07-05 10:12 PM . Last Modified: 2023-10-22 02:49 AM
