Posted: 2020-07-05 10:12 PM . Last Modified: 2024-04-03 12:33 AM
Hi!
We are noticing that temperature sensors in DCO web client are not refreshing after certain time. We have to refresh the page to see the current values. It seems strange due to DCE web client has the same sensors and an active refresh rate. I thought it'd work the same way in DCO's
Maybe is that DCO web client has a sort of auto-logoff option? If yes, where can I find it?
Kind regards.
(CID:148770668)
Hi Javier,
You are right, if the web client stays inactive for 2 hours, then the authenticated session would be terminated. This is hard-coded and not user configurable.
Kind regards
(CID:148771281)
Posted: 2020-07-05 10:12 PM . Last Modified: 2023-10-20 05:01 AM
