Is it possible to restrict users from adding custom properties?
  • EcoStruxure IT forum
  • Is it possible to restrict users from adding custom properties?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:24 AM . Last Modified: ‎2024-04-08 11:58 PM
661
Doing some house cleaning on the custom properties we have in DCO. Looks like a bit of sprawl happening. Is it possible to set permissions so that users cannot create or delete customer properties. I've tested and I believe this is not currently possible. Seems all users other than strictly view only can make these modifications.
(CID:106206005)
  • Data Center Operation
Hi Wes,
You are right, currently its not possible/supported to restrict users from adding/modifying custom properties. I have captured this as a feature request, wishing for that the Configure Custom Properties could be manageable (as an user rights feature) - I will email you the case no shortly, thanks.
Kind regards
(CID:106206033)
Hi Wes,
Kind regards
(CID:106206033)
Posted: ‎2020-07-03 03:24 AM . Last Modified: ‎2023-10-31 11:11 PM
