Posted: 2022-03-29 02:43 PM
Hi Everyone,
I have an issue in DCE Client V7.8.1 when I try to Log in DCE server by DCE Client, I get the error ( Invalid Network Address or time out) in DCE Client. while I Can access the server by the web as shown in the attached Pics.
I tried to increase the time out, change the port number, using HTTP and HTTPS ports and they didn't work yet.
Thanks in advance,
Posted: 2022-04-05 01:30 AM . Last Modified: 2022-04-05 01:31 AM
Hi Ahmed,
Try checking the client logs to see if there should be any useful info. Client log file usually located in Win. C:\Users\<username>\.isxc\7.8.1\.metadata\.log
If the client is unable to connect to server, then it might be network/routing related. Maybe something like firewall, antivirus program, proxy server, VPN, etc. 'located' between the client and server not permitting the desktop client to connect (but permitting the http/https connections).
Kind regards,
Posted: 2022-03-30 01:22 AM
Hi Ahmed,
It seems you are trying to connect (login) to servers private LAN, that is not supported for desktop client access.
Assuming the server is configured/setup properly, it should usually have 2 network interfaces: Public (LAN1) and Private (LAN2).
You can try to login via the IP address for the Public/LAN2 that you have assigned (configured during the installation).
Kind regards,
Posted: 2022-04-04 03:50 AM
Dear Jef,
I tried to connect to the server through Private and public Networks and it doesn't work for both.
Thanks.
Hi Ahmed,
Kind regards,
Posted: 2022-04-07 01:47 AM
Dear Jef,
thank You for Your replay actually, I checked it and it was a problem with Antivirus Firewall as you said, Thanks a lot
Posted: 2022-04-07 01:54 AM
Hi Ahmed,
You are welcome & many thanks for the update.
Kind regards,
