Interrogate Data Center Expert Remotely
  • EcoStruxure IT forum
  • Interrogate Data Center Expert Remotely
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 11:02 PM . Last Modified: ‎2024-04-03 12:16 AM
821
Goodafternoon,
It is Marco Gotelli from Deloitte Consulting.
We wanted to reach you out because we have to satisfy a connectivity requirement in order to bring data about energy consumption from Data Center Expert to our system for energy consumption analysis.
The goal of our activity is to interrogate Data Center Expert remotely and get automatically data about energy consumption about  each installed UPS every 15 minutes.
We would like to kindly ask you if it possible to access the Data Center Expert database remotely or use an API to get these data.
We wish to hear from you soon,
Best regards
(CID:150732872)
Replies 5
821
direct access to the DCE database is not supported.  However you can access the DCE web services api, documentation can be found here: https://sxwhelpcenter.ecostruxureit.com/display/public/DCIMDEVELOPER/StruxureWare+Data+Center+Expert...
(CID:150732878)
Hi Andrew, thank you for your answer we will check if we can find a solution in this way and if not we will get back to you. Thanks again, have a good evening
(CID:151060581)
821
Hi Andrew, I would like to ask you if it is possible to have credentials to test the API response without any risk of mess up the system while running.
Best regards
(CID:153552633)
Posted: ‎2020-07-05 11:03 PM . Last Modified: ‎2024-04-03 12:15 AM
as far as I know, our web services api is read only, so there isn't any risk of messing up the system.  Your customer should be able to provide with a user account on their DCE system for testing.  The only requirement should be "view access" for the device group(s) they want to monitor.
(CID:153553378)
Posted: ‎2020-07-05 11:03 PM . Last Modified: ‎2023-10-22 02:47 AM
