Installing DCE through OVA
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • Installing DCE through OVA
125
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-05 02:34 PM . Last Modified: β€Ž2024-04-03 11:52 PM
1457
We're trying to install the DCE server with the OVA.
After we do the deploy, we need to configure also the IP address in the server in order to use it.
For that, we need to access the server and it asks for a username and password..
Is that a default username&password for the server?
Another question - do you have instructions like this (there's a link on the word "this") but for the expert system?
Thanks.
(CID:137104196)
  • Data Center Operation
1457
Dear sheep,
From your question:
The default username and password is just apc/apc.
Yes, of course, instructions can be found on resource PDF Library in section StruxureWare Data Center Expert -> Additional Guides.
I hope this is what you need.
With respect.
(CID:137104212)
Replies 12
1458
Dear sheep,
From your question:
With respect.
(CID:137104212)
Posted: β€Ž2020-07-05 02:34 PM . Last Modified: β€Ž2024-04-03 11:51 PM
You really helped me, i'll work on it.
Thank you!
(CID:137104232)
Ok, if you have more questions, please ask πŸ˜€.
(CID:137104234)
ok so we're trying to get into the server with apc/apc also admin/admin (according to the guides you gave me) and it doesn't work.
Just for let you know, we're using OVA file in a virtual environment.
(CID:137104333)
Dear sheep,
Have you tried apc username without a password?
With respect.
(CID:137104408)
you mean only apc as username and empty password?
(CID:137104447)
Yes.
(CID:137104463)
ok we realized that the username and password are "apcsetup" and that worked πŸ˜€
(CID:137104489)
Posted: β€Ž2020-07-05 02:35 PM . Last Modified: β€Ž2024-04-03 11:51 PM
Dear sheep,
Probably, we did not understand each other πŸ˜€. All this time I told you about the default login/password to the DCE-client and the DCE web-GUI.
And the apcsetup password is used to log into the DCE-server CLI terminal for initial configuration.
With respect.
(CID:137104505)
ohh, now i got it. Maybe i didn't explained it well.
In the bottom line we solved the problem, that's what important πŸ˜€
(CID:137104539)
Ok, thanks for the good feedback πŸ˜€.
(CID:137104549)
Posted: β€Ž2020-07-05 02:35 PM . Last Modified: β€Ž2023-10-22 02:46 AM
