Posted: 2020-07-05 02:33 PM . Last Modified: 2024-04-03 11:52 PM
1.How do you add more width in the HOT AISLE space.
2. How do you lock racks into rows.
3. How do you turn racks back/front.
Thanks!
(CID:137104075)
Hi Muro,
1- Unlock the "Design mode":
Right click on your Hot Aisle containment system > Properties > Physical and then change its dimension:
2- right click on your rack > Snap, and select "Snap to row":
3- right click on your rack > Properties > Physical , and then change its orientation:
Kind regards
(CID:137104274)
The snap to row still does not work. They do not snap together.
(CID:137105284)
Hi Muro,
I've tested this moment ago without any problem.
Can you please share your steps, screens captures, illustrating that your snap to row is not working, thanks.
Kind regards
(CID:137106875)
However when I move the row the rack does not move with row.
(CID:137111412)
Hi Muro,
That's a two different thing - Snap to row would only enable snapping the rack to row.
If you want to move the whole row, including its equipment, then:
use the "Set Marquee select tool" (1) and select your whole row (2)
and change to the tool "Resize rows, gaps..." (3) and then move/relocate the selected row (and its items):
Kind regards
(CID:137111791)
Posted: 2020-07-05 02:33 PM . Last Modified: 2023-10-22 02:22 AM
