  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Energy & Sustainability Services
      • Green Building Scoring and Certification Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Remote Operations Devices Knowledge Base
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • Active Energy Management Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Installation of 3 x Netbotz 570 units - intermittent false alarms
A support forum for Data Center Operation, Data Center Expert, and EcoStruxure IT product users to share knowledge on installation, configuration, and general product use.
  • Communities
  • Installation of 3 x Netbotz 570 units - intermittent false alarms
  • Subscribe to RSS Feed
Send a co-worker an invite to the Exchange portal.Just enter their email address and we?ll connect them to register. After joining, they will belong to the same company.
Captain Jef Captain
78
Commander APC_Steve Commander
54
Commander gsterling Commander
50
Lt. Commander Cory_McDonald Lt. Commander
15
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 07:49 PM
485
This question was originally posted on DCIM Support by Robert Despy on 2018-07-04
Hi guys
So i have been installing these units for around 3 years and have had funny issues many times and have been able to figure it out, but currently this problem is on going and i just cant get it right.
I have installed 3x 570 netbotz in 3 different server rooms on the same site and i keep getting these false alarms very randomly on all three units, the item  that goes into alarm varies as well. it ran fine for 5 - 6 months and now this has started happening.
Items installed per room
  • 570 main unit
  • 150 rack mount
  • 155 wall mount
  • 2x160 camera
  • GSM modem
Items been monitored
  • Vesda 2 alarms
  • GEN 4 alarms
  • UPS 4 alarms
  • Door 1 alarm
  • Flood 2 alarms
  • Humidity 2 alarms
  • Temps 2 alarms
Firmware version 4.6.1
I have snaps and emails from client to assist if needed.
Kind regards please assist urgent.
spezialist scott.sexton  Saw your assist thought you may be able to assist.
(CID:132660616)
  • NetBotz
  • bug
485
This answer was originally posted on DCIM Support by spezialist on 2018-07-04
Dear Robert Despy,
Thank you for clarifying your problem. I'll try to help you, but all of the above should be checked by you on your sites.
Assuming that nothing has changed in the configuration of the monitoring system since its installation, the above mentioned random communication problems can be caused by several reasons.
  • After 5-6 months after installation, it is first necessary to check the quality of the electrical contacts along the entire length of the signal cable from the end device, for example Vesda, to your NetBotz-570. In this case, the temperature and humidity of the environment where your equipment is located may be important.
    I mean the reliability of the electrical contact in the RJ-45 connectors, that are used in the NetBotz-570 and patch panels, if such are used on your sites. In fact, I had to clean the RJ-45 connectors in the NetBotz appliances from the greenish oxide coating with any non-aggressive cleaning agent for electrical contacts (for example, Kontakt Chemie KONTAKT 60 or medical ethyl alcohol).
  • You can not also exclude external mechanical influence, for example strong vibration, on your equipment. I.e., this does not happen constantly, but sometimes, i.e. accidentally and not at all often. This also needs to be checked.
  • Finally, you can not exclude strong electromagnetic influence on your equipment, especially on signal cables. This can also happen not often and accidentally from any electrical mechanisms and systems. Here you need to know exactly where and how your signal cables pass from the end devices to your NetBotz-570.
  • Optionally, you can also update your NetBotz-570 firmware to the latest version 4.6.2. But as practice shows, this will not help to eliminate the above problems with electrical contacts, if they do exist.
I hope this helps you.
If you have any further questions, please ask.
With respect.
(CID:132660752)
Replies 6
This comment was originally posted on DCIM Support by spezialist on 2018-07-04
Dear Robert Despy,
Fron your question:
What kind of random alarms, for example, do you get? I.e., random alarms occur within a few days and then stop? Then after 5-6 months again this problem repeats? Did I understand you correctly?
With respect.
(CID:132660675)
This comment was originally posted on DCIM Support by Robert Despy on 2018-07-04
They began occurring after the 5 - 6 months of unit been installed.
I get unplugged alarms even though items are plugged in and no break in cable or power, i get failure alarms on the actual items as if unit cannot read the item.
It occurs randomly so for example on one unit i will get sevreal false alarms on lets say the door alarm which will go in alarm and out of alarm  for maybe around 1 hour, then it will return and become normal again, a week or so later the other unit does something similar.
Netbotz intermitent fault reoccuring..docx
(CID:132660688)
486
Dear Robert Despy,
With respect.
(CID:132660752)
Posted: ‎2020-07-04 07:50 PM
"Here you need to know exactly where and how your signal cables pass from the end devices to your NetBotz-570." - We have made sure to run on data only trays, but i do agree that there may be a form electromagnetic interference, and i will do a full check again on all cabling.
Is it not also a possibility that electrical feedback on the supposed low voltage relays could have created a fault on the unit?
I am in South Africa and where the units are installed did indeed become subject to high humidity.
"I had to clean the RJ-45 connectors in the NetBotz appliances" - I will definitely give this a try.
Thank you for assistant i will go through some of your points and see if they make any changes. As well as thank you for been so prompt on a reply.
(CID:132660776)
Dear Robert Despy,
If you use additional intermediate (i.e., between the end device and NetBotz-570) low-voltage electromagnetic relays, then maybe this is really so. For example, I have a Vesda device connected directly to the NetBotz-150 in the DC, and for the last five years, with normal humidity and temperature, no false alarms and no communication loss.
In this case, it is really necessary to check first the reliability of the electrical contacts in the RJ-45 connectors. I would do so.
With respect.
(CID:132660788)
You can subscribe to this forum after you log in or create your free account.
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
