"Unable to connect to APC update server"
  • "Unable to connect to APC update server"
129
72
Posted: ‎2020-07-04 07:48 PM . Last Modified: ‎2024-04-04 11:06 PM
2608
I am getting an error "unable to connect to APC update server."  I believe our Web Filtering is blocking it.  Is there an IP or URL that we would need to whitelist to be able to check/download firmware updates in Struxureware DCE?
(CID:132660212)
Hi Todd,
Yes, whitelist the following URL: updates.apc.com, to download the firmware updates into Data Center Expert.
Additionally, please see the knowledge base that references this:
https://www.schneider-electric.us/en/faqs/FA293307/
Kind Regards,
Andrew
(CID:132660224)
Replies 5
Hi Todd,
Kind Regards,
Andrew
(CID:132660224)
Dear Todd Walters,
As stated from my post  for this you need:
And, I solved the last problem quickly, as I understood, that for successful execute check Firmware Updates it is required to open outgoing connection from the DCE server to production update URL: https://updates.apc.com:443/. And practically only it is already enough for successful execute check Firmware Updates from the DCE client.
With respect.
(CID:132660236)
Posted: ‎2020-07-04 07:49 PM . Last Modified: ‎2024-04-04 11:06 PM
Thank you for the quick response!
(CID:132660239)
Thank you!
(CID:132660242)
Posted: ‎2020-07-04 07:49 PM . Last Modified: ‎2023-10-22 09:35 PM
