Posted: 2020-07-04 10:22 PM . Last Modified: 2024-04-04 03:22 AM
I have a customer with this error when he install the latest gateway for Ecostruxure Asset Advisor.
After fews minutes on the installing window. there are this error.
Thanks in advance for your help.
Regards
Samuel
(CID:134023839)
Dear MANSOURI samuel,
A couple of questions for your customer:
With respect.
(CID:134023856)
Window 10 Enterprise v1703, we have just one inverter for the server room
In the task manager, I ended the task on Postgre SQL before but I still have the same message
yes I deleted 2 folder:
1 in ProgramData
1 in Programs
and empty the TEMP in appdata \ local
Thanks in advance.
Kind Regards
(CID:134024391)
From your comment:
What is this another PostgreSQL process? Does it use any other software on your PC? To check and normal installation of the gateway software on the PC there should be no other PostgreSQL services.
Try and report the result.
With respect.
(CID:134024533)
The customer created a VM windows and he installed the soft on the VM.
On this VM, setup was done without problem.
Thanks for your help.
(CID:134024529)
Posted: 2020-07-04 10:23 PM . Last Modified: 2024-04-04 03:22 AM
Ok, thanks for the good feedback 😀.
(CID:134024532)
Tell us, please, have you solved this question or not?
With respect.
(CID:134026440)
Yes,
Regards
(CID:134026455)
(CID:134026461)
Posted: 2020-07-04 10:23 PM . Last Modified: 2023-10-22 02:45 AM
