Posted: 2020-07-04 10:23 PM . Last Modified: 2024-04-04 03:22 AM
There is a data center that is monitored by Desigo Insight (BMS software By Siemens). Its output protocol is BACnet, and I have to monitor it in DCO because I want to use the Capacity, Change, Incident, and energy management. Unfortunately, I have not used DCO and its option till now and don't know about it a lot. Is there anybody to help me? Is there a gateway for converting it to a protocol which is compatible with DCO?
Thanks in advance for your help.
(CID:134023878)
Posted: 2020-07-04 10:23 PM . Last Modified: 2024-04-04 03:21 AM
Hi Afsaneh,
There is no direct integration, but depending on requirements some data can be imported to DCO via ETL integration: External system integration through ETL
It can be offered as customized service (by CSP team), if you/customer should be interested I can ask someone to contact you (to discuss the details and price).
Kind regards
(CID:134024159)
Hi Afsaneh,
Kind regards
(CID:134024159)
Posted: 2020-07-04 10:23 PM . Last Modified: 2023-10-22 04:35 AM
