Incorrect russian fonts appearance in StructureWare Data Center Expert
  • EcoStruxure IT forum
  • Incorrect russian fonts appearance in StructureWare Data Center Expert
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 10:43 PM . Last Modified: ‎2024-04-03 12:22 AM
801
Hello!
I have StructureWare Data Center Expert client version 7.2.2.76 installed on Windows 10 Professional. We are using Russian interface for russian-speaking personal.
Some fonts (not all) are shown in wrong way as you can see on attached picture.
But the same client on Windows 7 Professional works as it should.
I would appreciate you for any comments that could help overcome this situation.
Best regards,
Alex.
(CID:149784813)
Replies 6
Hi Alex,
7.2.2 is quite old. The current version of DCE is 7.7.1. Issues such as this are usually fixed in releases of the product after the issues are discovered and not with patches for those older systems. I would suggest you get up to date with your version and then verify it is or it is not showing correctly.
Steve
(CID:149785127)
Dear Alex,
Please tell us, were you able to solve your problem or not?
With respect.
(CID:151062329)
The problem has been solved by installing 7.2.2 version on brand new PC with fresh Windows 7 Professional installation. Why it doesn't work on old PC - I don't know.
(CID:151062714)
I have managed to find a workaround. So you can mark this problem as "solved".
(CID:151062892)
Ok, very thanks for the good feedback.
(CID:151062952)
Posted: ‎2020-07-05 10:43 PM . Last Modified: ‎2023-10-22 02:43 AM
