In the 7.4 Schema can you confirm which table the measured load is for creating my own report.
  • In the 7.4 Schema can you confirm which table the measured load is for creating my own report.
129
72
Posted: ‎2020-07-02 09:48 AM . Last Modified: ‎2024-04-10 01:06 AM
877
i am creating a new report in Insight i have measured load in DC down to the rack level and this is also being shown at the cage level. In the 7.4 schema which table is this held as i have tried  configuration_item.ci_power_draw as utilized_power, but no luck.
any help appreciated.
(CID:93194099)
  • Data Center Operation
Hi Malcolm,
If you are looking for measurements that have been manually entered into DCO, then you will find this in the table "configuration_item_power_path". The column is named "pp_peak_power" and you will use the corresponding power receptacle ci_id to retrieve the line.
This field is in the following format: #L1:290.98 #L2:301.3768 #L3:NaN (unit=kW). I have written the following script to transform that text field into a sum of the 3 phases, you can just reuse it in your report by changing ["peak_power"] with your column binding name:
var result=0;
if(dataSetRow["peak_power"] != null){
 var javaString = (new Packages.java.lang.String(dataSetRow["peak_power"]));
 var cleaned = javaString.replace('","', "").replace("{", "").replace("}", "").replace("NULL", "0").replace('"#L1:', "").replace("#L1:", "").replace(" #L2:", ",").replace(" #L3:", ",").replace('";', "").replace("NaN", "0").replace(',"', "");
 var splitted=cleaned.split(",");
 for (var i=0; i
 result += (Math.round(splitted[i])/1000);
 result=Math.round(result*100)/100;
Guillaume
(CID:93194183)
Replies 5
Hi Malcolm, we will look into it, thanks for sharing.
(CID:93194157)
Hi Malcolm,
var result=0;
 for (var i=0; i
Guillaume
(CID:93194183)
Posted: ‎2020-07-02 09:49 AM . Last Modified: ‎2024-04-10 01:06 AM
Hi Guillaume,
Thanks you for your help i will give it a go.
Malc
(CID:93194185)
Hi Guillaume,
when i update my query with the following line (configuration_item_power_path.pp_peak_power as utilized_power,)
I recieve the following error.
ERROR:  missing FROM-clause entry for table "configuration_item_power_path"
LINE 10:  configuration_item_power_path.pp_peak_power as utilized_pow...
********** Error **********
SQL state: 42P01
Character: 411)
Any suggestions.
(CID:93194187)
Posted: ‎2020-07-02 09:49 AM . Last Modified: ‎2023-10-31 11:10 PM
