DCE backup fails
  • EcoStruxure IT forum
  • DCE backup fails
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:48 AM . Last Modified: ‎2024-04-10 01:06 AM
702
DCE backup fails
I am trying to run backups of DCE 7.2.0 to a windows share.   It test mounts successfully, and when requested to run a backup,  creates a 3.6 Mb file in the share folder, but concludes that backup failed.  When I go to the struxureware server, it states
IFS VFS: Autodisabling the use of server inode numbers on\\sharename\sharefolder .  This server doesn't seem to support them properly.  Hardware links will not be recognized  on this mount. Consider mounting with the "noserverino" option th silence this message"
Can someone explain this.
(CID:93194082)
Hi Ryan, Can we get more information on your configuration please? What Windows OS are you using? Are you backing up to a FAT32 or a NTFS? The message is only really a warning that we do not support hard links. We support soft/symbolic links. The reason why your backup is failing could be something different. Can you post a screenshot of the settings you are using for the Windows Share? Can we view the capture logs from the server please? Go to a web browser and type in the following
(CID:93194111)
Ryan,
I addition to Breda questions, do your corporate policies require NTLMv2? If so, that would be the reason we are able to test mount but fail during the backup. Please let us know.
Thank You
(CID:93913186)
Posted: ‎2020-07-02 09:48 AM . Last Modified: ‎2023-10-31 10:25 PM
