In DCE an ACRD in operation mode 'backup' is shown as 'unknown'
  • EcoStruxure IT forum
  • In DCE an ACRD in operation mode 'backup' is shown as 'unknown'
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 01:50 AM . Last Modified: ‎2024-04-05 04:01 AM
792
upgrading DCE to v7.4.3 and ACRD to aos390_acrptk374 did not solve the issue
(CID:126175467)
Replies 6
Dear Everard Eduard,
I suspect, that the problem is in the DDF-file for this device. Most likely, it is necessary to create an appropriate Request modification on Device Support (if there is no more recent DDF-file without this mistake), so that the DDF-team corrects this mistake.
With respect.
(CID:126175519)
Posted: ‎2020-07-04 01:50 AM . Last Modified: ‎2024-04-05 04:00 AM
Can you tell me which DDF is used for this device?
Why are DDF's for Schneider Electric devices not kept updated.
(CID:126175782)
Based on the screen shots, the DDF file "Schneider ACRD2G"  version 11 is used for this device. Please generate a WALK file using the instrcutions given in the following link, https://dcimsupport.apc.com/pages/viewpage.action?pageId=106207968 and send it to us while you create a request in device support. The WALK file will be the key to debug this issue.
With respect.
(CID:126175802)
Where do you see that "Schneider ACRD2G"  version 11 is used ?
I checked the backup, there is no DDF with this name.
Please send me the latest version.
(CID:126175938)
Posted: ‎2020-07-04 01:51 AM . Last Modified: ‎2024-04-05 04:00 AM
It isn't a 2G InRow because it uses aos390_acrptk374 !!!
(CID:126175961)
Posted: ‎2020-07-04 01:51 AM . Last Modified: ‎2023-10-22 02:43 AM
