StruxureOn Registration Failed
  • StruxureOn Registration Failed
129
72
Posted: ‎2020-07-04 01:51 AM . Last Modified: ‎2024-04-05 04:00 AM
1775
I am attempting to register my StuxureOn Gateway. I am using the 'Register' shortcut under More... > Registration. After entering all of my information (Company, name, email, etc...)  I get the following error
"Registration failed! This may be due to a wrong or already used registration code for the Gateway/Data Center Expert. Try repeating the process or contact support"
I have never used this registration, I only installed it today. I don't have a specific device to open support for, so contacting support seemed unhelpful. Can anyone explain why this might be happening?
(CID:126175480)
  • Asset Advisor
  • IT Expert
Replies 6
Hi Rodney,
Are you entering your information on the struxureon.com/manage/register page? The most recent version of the Gateway is 1.1.2.25. You can download it EcoStruxure IT.
  1. In the Gateway, open More…> Registration and select Register to start the registration of your organization and connect your Gateway.
    NOTE: The registration takes place in the management web interface. If you want to register from another machine, you can register by copying the code and entering it at struxureon.com/manage/register.
  2. Click or tap Register with StruxureOn and specify your organization's site address. The registration code gets linked to your organization when you select to Connect to gateway.
(CID:126175500)
Dear centrisit,
If you use the latest version of SxOn GW, as Jackie Lehr writes, and the error still exists, then you need to open a support ticket.
Exactly the same error has already been published in topic .
I hope this helps you.
(CID:126175513)
Dear centrisit,
Have you solved your issue or not?
With respect.
(CID:126183376)
spezialist,
The steps that Jackie provided are not what I was looking for. I know how to register the product, it is very straight forward. For some reason it just does not allow me to due to the error that I provided. I am using the latest version.
I did do as you suggested and opened a ticket but never received a response and looking at my requests it doesn't show that I ever opened one. I tried to open another ticket but got some ridiculous error when submitting the request.
I have officially given up. Thanks for attempting to assist.
(CID:126183462)
Dear centrisit,
In any case, many thanks for the feedback.
If you have any questions, please ask 😀.
(CID:126183508)
Posted: ‎2020-07-04 01:52 AM . Last Modified: ‎2023-10-22 03:59 AM
