Posted: β2020-07-02 04:29 PM . Last Modified: β2024-04-09 02:47 AM
The import function is not populating UCS blade servers in the correct slots.
I have a Cisco UCS 5108 chassis with 8 slots defines as full/half width. The blade servers are Cisco B200-M4 servers.
On the chassis, slot 1 is very top left and slot 2 is very top right, with slot 3 next left and slot 4 next right and so on. The import is populating blades from the top left down (1,2,3,4) then the top right down (5,6,7,8) regardless of what slot number is in the import worksheet.
I even tried to fake it out by listing the servers in the order of 1,3,5,7 and 2,4,6,8 to see if that sequence would populate correctly but the import disregards any particular order and places the blades vertically left to right no matter what order they are in the sheet.
(CID:103585405)
Posted: β2020-07-02 04:30 PM . Last Modified: β2024-04-09 02:47 AM
Hi Raymond, I will contact you soon (by direct email), thanks.
(CID:103585424)
Hi Raymond,
This is a short note to share with you/community that I can acknowledge the reported issue. Additionally you have kindly shared with me that the import is not picking up the equipment name for the blade servers. They are logged and captured as a product enhancement case.
Thank you.
Kind regards
(CID:103586500)
Hi Raymond,
A patch for resolving this issue has been created. You will receive further information about this patch from you local support team.
Jesper
(CID:104174925)
Posted: β2020-07-02 04:30 PM . Last Modified: β2023-10-31 11:08 PM
