Posted: 2020-07-02 06:21 PM . Last Modified: 2024-04-09 02:00 AM
Where can I download the log files for ITO server? I am having some problems with ITO. Should I download it from ITO server itself or I should see them under DCO server?
Thanks in advance
(CID:105457104)
Posted: 2020-07-02 06:21 PM . Last Modified: 2024-04-09 01:59 AM
Hi Kaan,
DCO server logs should contain the ITO logs as well. However ITO logs can also be collected from the ITO-server:
https://
Hope this helps,
Kind regards
(CID:105457108)
Hi Kaan,
https://
Hope this helps,
Kind regards
(CID:105457108)
Thanks!
(CID:105457174)
You are welcome, Kind regards
(CID:105457175)
Posted: 2020-07-02 06:22 PM . Last Modified: 2023-10-31 11:19 PM
