Posted: 2020-07-02 06:20 PM . Last Modified: 2024-04-09 02:00 AM
Dear Team,
I am facing a problem with cooling in DCO, as shown in picture my actual design is on the right side of picture everything is configure properly but when I press the cooling tab the one side of racks goes red. you can also see the error.
and in left picture I just put one extra cabinet in the front of the racks cooling are working normal. I just want to know where is the problem in my actual design.
(CID:105457071)
Hello Ali,
Without seeing the configuration myself I would first start my requesting to see if there are any errors being displayed when hoovering over each rack in the screen capture on the right. If so please act on the error to correct why the model is not reacting as expected. Otherwise, I would need a backup of your configuration to determine the issue.
Thanks Victor
(CID:105459561)
Posted: 2020-07-02 06:21 PM . Last Modified: 2024-04-09 02:00 AM
Hi Ali, Will you be able to share a backup with us? It is very difficult to determine the cause of this problem without a backup. Thanks Jesper
(CID:105459568)
Hi Ali, has your issue been resolved? Best, Stine
(CID:105459569)
Posted: 2020-07-02 06:21 PM . Last Modified: 2023-10-31 10:21 PM
