I need to see the current clock/time of the DCE server. We are having time sync issues where DCE server and 'ESB' are both pointing to the same time server but are ~1min diffent.
  • EcoStruxure IT forum
  • I need to see the current clock/time of the DCE server. We are having time sync issues where DCE server and 'ESB' are both po...
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 08:46 PM . Last Modified: ‎2024-04-04 04:04 AM
1076
(CID:132668707)
Posted: ‎2020-07-04 08:47 PM . Last Modified: ‎2024-04-04 04:04 AM
1077
Hi Jared,
The setting that I have mentioned will show the current date and time of the DCE server as shown in the image below:
However, if what you are looking for is an area on the DCE client that will show the set time (in real-time) I believe this is not available.
Justine
(CID:132668737)
Replies 6
1076
Hi Jared,
The time settings of the DCE appliance can be seen under System->Server Administration Settings->Time Settings from the DCE software client.
This is also where you can set the DCE as an NTP Server, change regional settings, time settings, and more importantly set the DCE appliance's date and time.
I hope this answers your question.
Cheers!
Kind regards,
Justine
(CID:132668711)
Sorry but I cannot see the current time here.
ie. the hour:minute:seconds ticking over.
(CID:132668719)
1078
Hi Jared,
Justine
(CID:132668737)
Posted: ‎2020-07-04 08:47 PM . Last Modified: ‎2024-04-04 04:03 AM
Hi Justine,
Yes, looking for the set time in real time.
Thanks for your help.
Jared
(CID:132668749)
You are welcome
(CID:132668759)
Posted: ‎2020-07-04 08:47 PM . Last Modified: ‎2023-10-22 02:38 AM
