Posted: 2020-07-02 11:46 PM . Last Modified: 2024-04-09 01:07 AM
I'm trying to use the DCO Excel Import function to associate my rpdu's to a room pdu and specific breaker. Is there a cross reference available for the template?
(CID:105465662)
Posted: 2020-07-02 11:46 PM . Last Modified: 2024-04-09 01:06 AM
Hi Dean,
Unfortunately It is not possible/supported to associate devices via excel import. It's good use might be when importing equipment for the first time, however using that without training wouldn't be recommended.
Kind regards
(CID:105465728)
Dean. I'm not aware of specific documentation, however If you download the excel import template from DCO and open the template file you should see a "receptacle" worksheet. That worksheet contains examples which show how to map an excel import entry to a specific floor pdu panel and breaker slot. You should be able to use those entries as a reference for adding a rack pdu and mapping it to a specific floor device, panel and breaker location. I attached a small xls example which shows how to add a pair of rack pdu's to a rack and assign these rack pdu's to an existing floor pdu, panel and breaker. Regards Greg Sterling
DCO75-template - Community.xls
(CID:105465837)
Posted: 2020-07-02 11:46 PM . Last Modified: 2023-10-31 11:08 PM
