Posted: 2020-07-02 11:45 PM . Last Modified: 2024-04-09 01:07 AM
kindly see the attached picture, I want location or hostname on email header have any idea.? without using Macro option because I want to use same email format.
DCE-7.2.7
(CID:105465579)
Hi Ali,
you can see the location in email header by changing the device name with your location in device NMC> administrator>General> Identification, see the attached screenshot.
Rana Ajmal
(CID:105465643)
Ali,
The only available way to customize email notifications would be to use the short message email option and use macros.
Best regards,
Cory
(CID:105465585)
Hi Ali,
Rana Ajmal
(CID:105465643)
(CID:105465811)
Posted: 2020-07-02 11:46 PM . Last Modified: 2023-10-31 11:03 PM
