I cannot access the server management interface
  • EcoStruxure IT forum
  • I cannot access the server management interface
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:53 AM . Last Modified: ‎2024-04-10 01:51 AM
427
I know there is a web based server management interface, where do I find it?
(CID:77299728)
  • Data Center Operation
The server management interface is accessed using the configure server link found on the server homepage http:// or directly using https and port 10000  https://:10000
If you cannot access the Webmin server management interface, check your browser settings.
For example, in Internet Explorer 9:
  • Open Tools>Internet Options>Privacy and select to Accept All Cookies.
  • Open Tools>Internet Options>Advanced and make sure JavaScript is enabled.
  • If needed, contact your IT department for policies, etc. possibly preventing access.
Version specific
If you are running a StruxureWare Data Center Operation version prior to 7.2.5, you may run into this issue:
Internet Explorer 10 (Windows 😎 does not accept security certificates less than 1024 bits. Webmin versions distributed with DCO prior to 7.2.5 use 512 bit certificates. A temporary workaround is to force Windows 8 to accept 512 bit certificates using the following command from the command prompt with administrator's rights:
certutil -setreg chain\minRSAPubKeyBitLength 512
For more information, see http://support.microsoft.com/kb/2661254
(CID:77299746)
Posted: ‎2020-07-02 06:53 AM . Last Modified: ‎2023-10-31 11:08 PM
