Posted: 2020-07-02 06:53 AM . Last Modified: 2024-04-10 01:51 AM
I'm currently not seeing any alarms in DCO in my system?
(CID:77299730)
This might be due to wrong or missing connection setup between DCO and DCE. Ensure the connection between StruxureWare Data Center Operations and StruxureWare Data Center Expert has been configured properly in DCO System Setup>External System Configuration.
If you are using a secure connection for the external system integration to DCE, alarms will not show up in DCO until the secure connection has been configured properly and the certificate has been trusted on both DCE and DCO servers.
Ensure the certificate is trusted on both servers:
If that did not solve the issue feel free to get back to us.
(CID:77299748)
Posted: 2020-07-02 06:53 AM . Last Modified: 2023-10-31 11:45 PM
