I can't find Cisco UCS-FI-6332 in Genome Libray
  • EcoStruxure IT forum
  • I can't find Cisco UCS-FI-6332 in Genome Libray
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:17 PM . Last Modified: ‎2024-04-05 12:39 AM
600
I can't find Cisco UCS-FI-6332 in Genome Libray.
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-s...
BR
Carsten
(CID:129406702)
  • Data Center Operation
Hi Carsten,
In general, if you are unable to find your device in the Genome Library, then I would suggest:
  1. post a request here: http://sxwhelpcenter.ecostruxureit.com/devices, so the Device Support team can capture the request and create/add the item for the next Genome update.
  2. as a work-around, for the time being you might want to find a similar device (from the Genome Library), and then customize it in your Genomes (most common changes/customization, additional to its General description,  could be device physical & power settings). Double-click/right-click on the device > Properties and then enter your data:
Kind regards
(CID:129407958)
Posted: ‎2020-07-04 03:17 PM . Last Modified: ‎2023-10-22 02:37 AM
