Posted: 2020-07-04 03:17 PM . Last Modified: 2024-04-05 12:39 AM
Unfortunately a customer did tick all the SSL protocols rejections and now cannot login to the webmin anymore. The DCO installed is 8.2.2
How can the customer access the webmin area again?
Thank you for a feedback in advance.
(CID:129406779)
Hi Lukas,
To resolve the webmin access, try the following:
Log in to server (via console or ssh login)
Edit the file /etc/webmin/miniserv.conf
find the following line, and change:
no_tls1_2=1
to
no_tls1_2=0
Save the file.
And then type:
systemctl restart webmin
(you can use vi-editor or nano to edit the file).
Now you should have access to webmin using the protocol TLSv1.2
Kind regards
(CID:129406853)
Posted: 2020-07-04 03:18 PM . Last Modified: 2024-04-05 12:39 AM
Hi Lukas (Lukas Jegerlehner)
Wondering if this is resolved or you/customer need some help?
Kind regards
(CID:129407918)
Hi Jef,
unfortunately when I connect through SSH the permission to the file is denied.
(CID:129412908)
Hi Lukas,
edit the file as sudo:
sudo nano /etc/webmin/miniserv.conf
Kind regards
(CID:129412920)
Hi Jef,
the user apc is not listed within the SUDO, thats why i cant open the file. Do you guys have a cent OS user which can edit the miniserv.conf?
(CID:129412957)
Hi Lukas,
No, we do not have such user.
CentOS user name(s) and rights manually defined (by you/customer) during the installation.
Kind regards
(CID:129412985)
Posted: 2020-07-04 03:18 PM . Last Modified: 2023-10-22 02:57 AM
