Share Your Feedback ā Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us deliver the results you need faster and more accurately. Click here to take the survey
Posted: ā2020-07-04 08:05 PM . Last Modified: ā2024-04-04 04:20 AM
Hi
I am testing Tripp-Lite UPS unit compatibility with Struxureware software and found that Struxureware is not able to report any information, critical alarms from Tripp-Lite UPS unit in short or details email alert. All i can get is communication lost alert when device looses connection to the Struxureware software.
I added the units using SNMP and then installed the DDF associated to Tripp-Lite web card ā WEBCARDLX from http://sxwhelpcenter.ecostruxureit.com/ Website. I can view the device sensors which is a good sign of device being able to communicate with Struxureware software.
Under the alarm configuration tab I can see āUPS On Batteryā alarm sensor for the Tripp-Lite units as well.
All the information getting displayed for Tripp-Lite is same as other APC units we are testing under Struxureware but for some reason I am not getting the email alarmās from Tripp-Lite units.
I am not sure if we need to get the correct DDF file created from DCIM support as Tech support guys advised to post question to the DCIM support to look into this matter.
GP
(CID:132663735)
Hi Gagan!
Check that your devices are added to correct notification policy ubder the "Devices" tab.
It is important thing that device alarms ("blue tab") can be linked to one notification policy only. And threshold alarm ("orange tab") can be linked to several policies.
Communication lost alarm is "orange" one and its created automatically when you discover your device.
(CID:132663818)
Hi Valentin
As you can see in the screen shot the device alarm - UPS Battery discharged, UPS Low battery and UPS On battery are part of default notification policy.
The default notification policy has all devices listed under it and a Threshold (Communication status and State mismatch - Battery status created by me listed in it). I have only created one alarm action which is Send E-mail alarm action and no other alarm options are present in the DCE client.
(CID:132664271)
Dear Gagan,
From your question:
Tell us, please, what version is your SNMP DDF-file for WEBCARDLX? Also, please tell us which model of your Tripp Lite UPS? This information is important.
You mean the alarm configuration tab in DCE software? Please show a screenshot of this.
The fact is that today, from the web-resource Device Support, I was able to download the SNMP DDF-file for WEBCARDLX tripplite_webcardlx.xml: its version 2. And in this DDF-file there are only three configured Device Alarms:
Tlp Env Temperature In Alarm Condition Present/Cleared (warning)
Tlp Env Humidity In Alarm Condition Present/Cleared (warning)
Tlp Env Input Contact In Alarm Condition Present/Cleared (warning)
I did not find in this DDF-file specified by you "UPS On Battery" alarm sensor...
With respect.
(CID:132663832)
Posted: ā2020-07-04 08:05 PM . Last Modified: ā2024-04-04 04:19 AM
Alarm configuration tab
(CID:132664228)
Did you check your notification policy?
Are there your devices under "Device" tab?
(CID:132664276)
Posted: ā2020-07-04 08:06 PM . Last Modified: ā2024-04-04 04:19 AM
Also, if you have UPS State sensor or similar, you can create state treshold and receive alerts this way.
(CID:132664278)
Hi Valentin
Yes we see the devices under the Default -> Notification policy -> Devices TAB.
Threshold - I created a State Mismatch Threshold for Battery Status.
Threshold is also linked to Default Notification Policy and Default notification has only one alarm Test123 created no other duplicate present under it.
As per the Threshold policy created we should get an alarm when Battery gets discharged after power outage. But its not happening.
(CID:132664317)
Dear Gagan,
Thanks for the screenshots and detailed information.
In addition I also installed DDF for Tripp Lite UPS - Version 6
This information was not enough for me to understand in your question š. Now everything is clear to me and everything corresponds to reality.
I spoke with Tripp Lite support and they told me that Tripp Lite units uses Port 161 and 162 for sending and listening to SNMP traps.
SNMP walk query send over port 161 and listen to device on Port 162.
Can this be our issue of not able to get alerts from Tripp Lite UPS ??
This does not matter, since the DCE-server polls the 3rd-party devices on a standard 161 SNMP port and does not accept SNMP traps from them (as opposed to native Schneider Electric devices).
I.e., when your UPS is really running on batteries, you do not see a critical alarm in the DCE-client? Do I understand you correctly?
Or a critical alarm, still appears in the DCE-client, but you do not receive an e-mail notification about this?
With respect.
(CID:132664551)
Dear Gagan,
Tell us, please, did you solve your problem or not?
With respect.
(CID:132670115)
I realize this post is older, but in case anyone else is struggling with the same issue, I thought I'd chime in. Short version: this should be fixed in WEBCARDLX versions 15.5.2 and later. Details on why I believe that to be true are below.
*Note: I work for Tripp Lite support and worked with a customer on a similar issue. I became aware of this thread because other users have seen it and thought the issue still exists. The issue I was working on is what prompted me to post this thread last year: Need a DDF file for the Tripp Lite WEBCARDLX Struxureware v7.2.2*
I believe the root cause of this particular problem was related to an issue with WEBCARDLX firmware versions from 15.04 to 15.5.1. We resolved the issue in firmware 15.5.2.
The issue was: the WEBCARDLX was NOT changing the number reported to " upsAlarmsPresent" nor populating the " upsAlarmTable" when an alarm was present. Since Struxureware polls the UPS MIB, and not UPS vendor-specific MIBs (e.g. in our case tlpAlarmsPresent) , it was unable to detect the alarms on the WEBCARDLX. This being the root cause is also consistent with spezialist 's point about the SNMP Traps not mattering in this case.
The customer I was working with was able to confirm firmware 15.5.2 resolved their issue. Note: we have since released later firmware that should also work.
Gagan wish I would have saw this sooner. If you are still struggling with this issue, feel free to reach out to me and I can try and help.
(CID:140217160)
**Adding my comment above as an "Answer"**
(CID:140217193)
Posted: ā2020-07-04 08:06 PM . Last Modified: ā2023-10-22 02:37 AM
Youāve reached the end of your document
