I Need Support on Linux Commands to Install DCO on G9 Server
  • EcoStruxure IT forum
  • I Need Support on Linux Commands to Install DCO on G9 Server
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:36 PM . Last Modified: ‎2024-04-09 01:54 AM
789
Dear Team,
Kindly assist with detailed linux commands to install DCO on a HP G9 Server on Red Hat Enterprise Linux as described here.
Felix.
(CID:105457751)
  • Data Center Operation
Replies 4
789
Hi Felix,
I'm not sure what details you are looking for, as described in the installation instructions, simply you need to upload the proper installation file to the Red Hat server, extract it, and then execute the install script. Can you please explain what is failing for you?
If the DCO installation is unsuccessful, then perhaps the installation file is damaged or perhaps the installation requirements are not fulfilled (specially the requirement concerning active RHEL subscription with access to certain channels!).
Kind regards
(CID:105457766)
Hi Jef, With the installation of the DCO I get several errors and eventually the installation fails as shown below.
(CID:105457837)
Hi Felix The installer cannot find any Red hat packages. Please ensure the required Red Hat subscription are active on the server. And optionally, access to Red Hat Enterprise Linux Server x86_64 installation media is available either by DVD or Red Hat satellite. It is documented in the "Installation requirements" section in the link you gave.
(CID:105457909)
Posted: ‎2020-07-02 06:36 PM . Last Modified: ‎2023-10-31 11:09 PM
