Posted: 2020-07-05 11:30 PM . Last Modified: 2024-04-03 12:07 AM
HI All,
I recently installed a temperature and humidity sensor using a sensor pod. But i noticed the humidity sensors(only) on the last two sensor pods shows unplugged. After logging into the device i observed that the humidity sensors show values occasionally. I have replaced the sensors with new ones but the problem still persists. The sensors are connected to the last on the last sensor pods on the loop. Whatr could be the problem?
(CID:151584979)
Posted: 2020-07-05 11:30 PM . Last Modified: 2023-10-22 02:36 AM
