How to use script on multi select function for insight ?
  • EcoStruxure IT forum
  • How to use script on multi select function for insight ?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:00 AM . Last Modified: ‎2024-04-05 03:39 AM
835
Hello Everyone ,
About our insight tools , we can enable the multi select function , Please refer as below ,
How to use script on multi select function like select * from name in( 'n1' , 'n2' , 'n3') ?
Kindly advise ,thank you.
Best Regards
(CID:126882940)
  • Data Center Operation
Replies 4
Hello, I'm keen to dog into your question but this is a very busy time of year for me so  I though I'd let you know of my interest but lack of time.  Sorry that doesn't help you much.  If its not too urgent I can check in next few weeks
Kind regards
Ed
(CID:126884365)
Hello Ed ,
Thank you for kindly response , this case is not too urgent and we are pleasure to see your check when you are available , thank you . : )
(CID:126884412)
Hello Chu Li Wei,
Basically you need to script your data set. What I would do is to add a unique identifier to your query in the data set like this:
select * from table where field in ('SomeUniqueString')
Then in your data set script in the before open option I would add:
this.queryText = this.queryText.replace("SomeUniqueString", params["p_name"].value.join(" ',' "));
This should replace the "SomeUniqueString" string with the multiple values from your parameters and insert them in your query.
If your parameter is of type Integer and not string (p_name indicates its a string), then you need to remove the ' ' from the query and the script.
Hope this helps.
Morten
(CID:126886472)
Posted: ‎2020-07-04 03:00 AM . Last Modified: ‎2023-10-22 02:35 AM
