How to upgrade DCO from 7.2.1 to 7.5 ?
  • EcoStruxure IT forum
  • How to upgrade DCO from 7.2.1 to 7.5 ?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 01:34 PM . Last Modified: ‎2024-04-09 04:30 AM
689
Hi All ,
I know 7.2.5 to 7.3 must be used migration , now I used DCO 7.2.1 .
I tried to used the 7.2.1 backup file to restore 7.4 or 7.5 , it can not login DCO client and seems to failure .
What's the best procedure for upgrade from 7.2.1 to 7.5 ?   Did it must used migration for some version ?
Pls kindly advise , many thanks .
Best Regards
Hi Jef ,
I'm bit confuse for your comment , as I know , the way what u mean is restore , right ?
If use migration , we can login the client of new server , and enter migration mode to connect the old server , right ?
Best Regards
(CID:98304020)
  • Data Center Operation
Replies 4
Hi Chu, Are you using the credentials defined in 7.2.5, which might have been changed from the defaults?
(CID:98304021)
Hi Chu,
I would try the migration feature, eg. a) install 7.5 on a new server, b) copy the 7.2.1 backup file to the new server, c) and then start the migration on the new server (7.5).
(CID:98304031)
Hi Chu,
I've suggested a migration process, that involves the following steps:
1. Install DCO 7.5 on a new server
2. Copy/upload the "7.2.1 backup file" to the new server (ex. to /data/backup or /tmp)
3. Via 7.5 client connect/log-in to the new server
4. go to: System Setup > Migrate from StruxureWare Operation
 5.  and then follow the migration wizard,
(CID:98664527)
Posted: ‎2020-07-02 01:35 PM . Last Modified: ‎2023-10-31 11:07 PM
This is a heading
