Posted: 2020-07-02 01:34 PM . Last Modified: 2024-04-09 04:30 AM
I tried to upgrade from 7.3.x to DCO 7.5 but the upgrade failed.
Note: the file is : StruxureWareDataCenterOperation-Upgrade-7.5.0.tgz
(CID:98304007)
Hi Ahmad, I'll try to find a person who might be of help here. @community - any piece of advice?
(CID:98304037)
Hi Ahmad,
I would suggest to check/verify:
a) if there is enough free disc space (at least 10 GB) on the server
b) carefully reading the upgrade instructions: http://dcimsupport.apc.com/display/public/UAOp74/Upgrading+to+StruxureWare+Data+Center+Operation+7.5
c) make sure that the upgrade file is not "damaged", (StruxureWareDataCenterOperation-Upgrade-7.5.0.tgz, file size: 2.054.290 KB), if needed re-download the file and try again.
d) try uploading the file to the server and then start the upgrade (if the upgrade file is not located on the server).
(CID:98304040)
Posted: 2020-07-02 01:34 PM . Last Modified: 2023-10-31 10:47 PM
