Posted: 2020-07-04 12:49 AM . Last Modified: 2024-04-05 04:27 AM
I'm asking for information how to track create/update/delete equipment operations in DCO. I can't find anything in DCO logs and DCO documentation,
(CID:126165475)
Hi Dmitry,
Try the "Audit Trail" reports (desktop client, Analytics Reports -> Audit Trail)
hope this helps,
Kind regards
(CID:126165484)
Hi Dmitry,
hope this helps,
Kind regards
(CID:126165484)
Thank you for your fast response.
I don't have such report. I have only this (look at the screenshot below).
(CID:126165493)
Hi Dmitry, The Audit Trail report is part of the Change Module. You need a Change Module license in order to enable this feature.
(CID:126165509)
Thank you!
(CID:126165517)
Posted: 2020-07-04 12:49 AM . Last Modified: 2023-10-22 02:35 AM
