How to reset Device ID of sensor POD 150 cascaded with Netbotz 550
  • EcoStruxure IT forum
  • How to reset Device ID of sensor POD 150 cascaded with Netbotz 550
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:29 PM . Last Modified: ‎2024-04-05 12:13 AM
1818
Dear Mates,
Hope you all are doing well, I am connecting the Netbotz Sensor Pod 150 Qty:11 with Netbotz 550, but there is a problem, i,e
few of the Sensor pods were existing and others were new , now after cascading, Sensor POD Identification was not in proper sequence, Rack Monitor 550 - 150 IDs were in below sequence
NB550 - ID 6 - ID 11 - ID 5 - ID 2 - ID 10 - ID 9 - ID 4 - ID 12 - ID 3 - ID 7 - ID 8
Please guide that how it can be sorted out without changing the device placement.
Please note that, I had installed the system as per installation manual  and put terminator into last sensor POD out-Link, and then powerup the system.
(CID:130094806)
  • NetBotz
Posted: ‎2020-07-04 04:29 PM . Last Modified: ‎2024-04-05 12:12 AM
1817
Hi Mian,
The 150 uses ID #1 by default. If the device sees another pod in the chain has that ID, it gives it #2 and so on. Subsequently that pod will always have ID #2 until it is added to a chain where #2 (or whichever it was last given) is taken and it will get the next available ID. If it's been attached to a chain, it will retain that ID. There is currently no way to manually alter these IDs. It is a suggested enhancement that's already in the system and I will add this post to that enhancement request however I do not know that it is going to be addressed and if so, when it may be. Sorry.
Steve
(CID:130094821)
Replies 4
1818
Hi Mian,
Steve
(CID:130094821)
Hi Steven Marchetti,
Thanks for your prompt response, its OK if there is not solution to this problem,
but i have a question here, suppose I reset my Netbotz Rack monitor 550, will this affect any sensor pod Identification # or not?
Is there any way to hard reset my Netbotz sensor pod 150 ?
(CID:130094836)
Sorry Mian but no. Resetting the NetBotz parent device will not reset the IDs shown on the sensor pod 150s. As I tried to infer, it is in the memory of the pod and only changes when there is a conflict with another pod with the same number and it should increment by 1 (or until it reaches a non-conflict number) . If resetting the appliance was an option, I would have suggested that.
Steve
(CID:130094838)
Posted: ‎2020-07-04 04:30 PM . Last Modified: ‎2023-10-22 02:34 AM
