Does Portal support AD integration on port 636 (LDAPS)?
  • Does Portal support AD integration on port 636 (LDAPS)?
127
65
Posted: ‎2020-07-04 04:29 PM . Last Modified: ‎2024-04-05 12:13 AM
848
Please advise if Portal support AD integration on port 636 (LDAPS)?
The below 2 links are over unsecured port 389.
http://sxwhelpcenter.ecostruxureit.com/display/public/Portal/User+authentication+with+LDAP+and+AD+in...
https://web.liferay.com/community/wiki/-/wiki/Main/LDAP+with+AD+in+Liferay+6.0.5
(CID:130094611)
  • Portal
Hi YJ,
From documentation, Portal is based on Liferay Portal 6.1 CE GA2 (6.1.1).
It does support LDAPS on port 636, but requires user to import the certifcate issued by your LDAPS server using keytool.
Can you try importing the certificate, and use ldaps in Portal? To quote from the 2nd link:
The import is handled by a command like the following:
keytool -import -trustcacerts -keystore /some/path/jdk1.5.0_11/jre/lib/security/cacerts -storepass changeit -noprompt -alias MyRootCA -file /some/path/MyRootCA.cer
The keytool utility ships as part of the Java SDK.
Once this is done, go back to the LDAP page in the control panel. Modify the LDAP URL in the Base DN field to the secure version by changing the protocol to ldaps and the port to 636 like this:
ldaps://myLdapServerHostname:636
Edit1:
keytool is part of Java utility, so it will be in the folder where Java is installed, e.g:
C:\Program Files\Java\jre7\bin
Leaving this question open for others to chip in.
Chris
(CID:130095130)
Posted: ‎2020-07-04 04:29 PM . Last Modified: ‎2023-10-22 01:55 AM
