Posted: β2020-07-04 04:28 PM . Last Modified: β2024-04-05 12:13 AM
Hi Team,
One of my customer does have 8 DCE units, they run the DCE client on a citrix server, what they like to have is the following.
8 times a shortcut of our DCE client with the pre-configured IP address already in the hostname/IP address files so they only have to enter the login/password, this means they don't have to select the IP address from the pull down menu.
Sounds easy but is this possible π
(CID:130094334)
Hi Cees!
IP adresses from this drop-down list are stored in user profile and not linked with shortcut for the app.
There is string PREFERENCE_LOGIN_list=
It seems that only way to reach your goal is to edit this string with needed values when user runs corresponding shortcut. Or replace whole file with client settings.
I'm not familiar with Citrix, but if it's possible to create different user environments (.isxc folders) and redirect it for each shortcut, it should work.
(CID:130094523)
Dear Cees de Vogel,
Thank you for the useful life hacking π. I think, that it can be placed in the section TIPS AND IDEAS. I, for example, simultaneously work with three DCE-servers.
Very thanks for the support.
(CID:130094404)
Hi Cees!
(CID:130094523)
Hi Valentin,
Great idea, will try to figure this out together with the customer, will keep you informed,
best regards,
Cees
(CID:130094688)
Hi Spezialist, thx for your reply, see answer below from Valentin, maybe a idea for you also
(CID:130094685)
Thanks for the great idea π.
(CID:130094881)
Posted: β2020-07-04 04:29 PM . Last Modified: β2023-10-22 03:05 AM
