How to purge local repository ?
  • EcoStruxure IT forum
  • How to purge local repository ?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 03:54 PM . Last Modified: ‎2024-04-09 02:59 AM
625
Hi All,
As I received warning: Filesystem for repository Local reports 200.8 MB free, which is less than the failsafe amount of 206.3 MB. Marking this repository as FULL.
(com.netbotz.server.services.repository.impl.RepositoryCapacityJob)
That caused upgrade from 7.2.5 to 7.2.6 failed.
I currently using Remote Struxureware Repository, and Struxureware Server doest not let me select the Local Repository to Run Manual Purge. Please help
Minh
(CID:102925418)
625
Minh,
Since the local hard drive is so small, once this issue is resolved I suggest selecting the option to use remote storage only. The local disk of 4.03 gig (the rest is for the OS) is full as per your screenshots. What I suggest is turning off the server, adding another drive of at least 20 gig (preferably more) via the VMware administrative interface (probably Vsphere), and then restarting the server. When that is done, create a backup and try your upgrade again. Do NOT try to increase the current drive size as that will not work and can only cause issues.
Steve
(CID:103583879)
Replies 5
627
Hi Minh,
If you are using remote repository only then it may not allow you to choose local when purging. Is this a VM? If it is a VM, how many hard drives are associated with the VM? What is the size of the default drive? What are your repository and purge settings? How much free space is there on the remote share?
Steve
(CID:103583780)
Hi Steven,
Thanks for your respond. Below is our details of VM:
.  Is this a VM? Yes, it's VM
.How many hard drives? There is only one 18 Gb hard drive
.What are your repository and purge settings? and How much free space is there on the remote share? See images below
Minh
(CID:103583833)
626
Minh,
Steve
(CID:103583879)
Hi Steven, Thanks for your solutions. The VM struxureware upgraded succesfully without any problems. Regards, Minh
(CID:103583900)
Posted: ‎2020-07-02 03:54 PM . Last Modified: ‎2023-10-31 11:06 PM
