Posted: β2020-07-02 03:02 PM . Last Modified: β2024-04-09 03:59 AM
Hi everyone!
How to model Emerson PCW unit in DCO?
It's a downflow unit, but it stands on legs and flows above raised floor.
There are no perforated tiles in design.
What type of cooling unit I need to use in order to model cooling properly?
(CID:100340554)
Hello Valentin,
I would recommended using the vertical vent option for this model. The reason I recommend that type of cooling model is because you have the ability to place the supply air at the bottom of the wall and the return above . This would allow the model to better represented. Please see the EcoBreeze section of the video below.
How to model different types of cooling
Thank You
(CID:100340567)
Posted: β2020-07-02 03:02 PM . Last Modified: β2023-10-31 11:06 PM
