Posted: 2020-07-02 06:11 PM . Last Modified: 2024-04-09 02:03 AM
Hi All,
I have integrated DCO and DCE with AD/LDAP. But i could not integrate Portal with AD/LDAP. Please let me know how can i do this?
Regards
Kerem
(CID:105456823)
Posted: 2020-07-02 06:12 PM . Last Modified: 2024-04-09 02:03 AM
Hello Kerem
you can setup integration with LDAP server in the Control Panel, Portal Settings, Authentication - Tab LDAP
You will also find some instruction under following link:
https://www.liferay.com/community/wiki/-/wiki/Main/LDAP+with+AD+in+Liferay+6.0.5
Regards
Michael
(CID:105456868)
Hi kerem.yilmaz
The Authentication configuration in the portal is found in "Control Panel"->"Portal Settings"->"Authentication (found in right side menu) and then choosing LDAP.
Jesper
(CID:105456865)
Thanks Jesper
(CID:105456871)
Hello Kerem
Regards
Michael
(CID:105456868)
Thanks Michael
(CID:105456870)
Hi Community,
I have already integrated LDAP and Portal, but when i try to log in some id and password i can not log in. Actually, i can not see any person in portal however success integration..
Regards
Kerem
(CID:105465251)
Posted: 2020-07-02 06:12 PM . Last Modified: 2023-10-31 11:06 PM
