Posted: 2020-07-02 02:29 PM . Last Modified: 2024-04-09 04:11 AM
(CID:99157600)
Posted: 2020-07-02 02:30 PM . Last Modified: 2024-04-09 04:11 AM
Hello Santosh,
I did not see any question within the post so I am not sure if you are having an issue or just a general questions on the integration. Below is the URL that explains the DCO/ HP OpenView integration.
http://dcimsupport.apc.com/display/UAOp74/HP+OneView+Integration?queryString=Hp%20open
Thank You
(CID:99157611)
Hello Santosh,
Thank You
(CID:99157611)
VSales HP OpenView and HP OneView are two separate products. I assume there is no straightforward integration with OpenVIew?
(CID:99157648)
VSales
Hi, i can see HP Oneview integration is available. But we are using HP Openview in our enviornment , which i want to integrate with Struxureware.
(CID:99157868)
Hi James, Is there any way to integrate HP Openview as well ?
(CID:99157712)
Posted: 2020-07-02 02:30 PM . Last Modified: 2024-04-09 04:10 AM
Currently, there is no out of the box integration with HP Openview. StruxureWare Data Center Operation does support ETL which would be a method for this integration if OPenview supports ETL.
(CID:99157717)
Vineet K. Sarin - is it possible ?
(CID:99157715)
Posted: 2020-07-02 02:30 PM . Last Modified: 2023-10-31 11:06 PM
