Posted: 2020-07-04 04:11 AM . Last Modified: 2024-04-05 03:04 AM
I cannot find where to import excel data into Struxureware DCO 8.2, it was a normal function in 7.X under the file- import tab, does anyone know where this is moved to?
(CID:128067147)
You have to Edit the StruxureWare Data Center Operation ini file. in the
installation directory of DCO client application (e.g. C;\Program Files
\StruxureWare Data Center Operation xx.x\application)
Please remove comment (# character) from the beginning of this line:
-Dexcel.importer.enabled=true
(CID:128067525)
(CID:128067525)
also this has always been a silent feature and disabled by default
(CID:128067780)
Posted: 2020-07-04 04:11 AM . Last Modified: 2023-10-22 02:31 AM
