Posted: 2020-07-03 01:27 PM . Last Modified: 2024-04-08 01:37 AM
I know I saw a place that I could specify the poling interval on a per device basis, but can't seem to find it now. What menu item is it located under?
(CID:113641265)
Dear John,
In order to update the Device Scan Settings, go to Device–>SNMP Device Communication Settings–>Device Scan Settings
Select the device for which you want to update the settings–>Edit Device Scan Settings
I hope it helps.
Bala
(CID:113641275)
Dear John,
I hope it helps.
Bala
(CID:113641275)
Posted: 2020-07-03 01:27 PM . Last Modified: 2023-10-22 02:29 AM
