How to delete "old" discoveries from ITO server?
  • EcoStruxure IT forum
  • How to delete "old" discoveries from ITO server?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 05:21 PM . Last Modified: ‎2024-04-09 02:29 AM
748
Dear All
Is there way to delete "old" discoveries from ITO server itself? If yes,can you please guide how to do it? Assuming that it has to be done true ITO web min page.
Thank you in advance
Marcis
(CID:104173979)
  • Data Center Operation
  • IT Optimize
746
Hi Marcis,
I think you can do it via DCO, assuming you have added the ITO server to your DCO,
In Planning Device Association, Unassociated Devices,
expand your ITO > right click on the discovered host > Remove ,
Kind regards
(CID:104173983)
Replies 5
747
Hi Marcis,
Kind regards
(CID:104173983)
Thank you Jef.
(CID:104173991)
Posted: ‎2020-07-02 05:22 PM . Last Modified: ‎2024-04-09 02:29 AM
You are welcome Marcis.
(CID:104173992)
Hello Maris, Jef is correct, you should be able to delete previously discovered assets directly from the DCO client as he described above. The same is true if you wish to delete the discovery definition. You can delete the individual discovery definitions from the "server discoveries" pane in the DCO rich client. Regards Greg Sterling
(CID:104174039)
Posted: ‎2020-07-02 05:22 PM . Last Modified: ‎2023-10-31 11:04 PM
