How to convert a .crt. SSL Cert to the .pem format required by DCE
  • EcoStruxure IT forum
  • How to convert a .crt. SSL Cert to the .pem format required by DCE
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 02:18 PM . Last Modified: ‎2024-04-09 04:14 AM
611
What is the method to do this?
(CID:99157355)
Hi Ed,
I'm not an expert and not sure if it will work. But this is what I learnt when looking into it.
As I understand it depends on what type of encoding (DER or PEM) is being used in the .crt certificate.
It might be the .crt is actually already created using PEM encoding and therefore only the extension needs to be changed.
OpenSSL provides a library that can be used for identification of encoding and conversion.
 More information can be found in this article:
https://support.ssl.com/Knowledgebase/Article/View/19/0/der-vs-crt-vs-cer-vs-pem-certificates-and-ho...
/Søren
(CID:99157372)
Posted: ‎2020-07-02 02:18 PM . Last Modified: ‎2023-10-31 11:04 PM
